Thonglin
Dec 04, 2019Aspirant
SCP protocol on ReadyNAS 3138
Dear Support, I try to configure the backup from Cisco switch to ReadyNAS 3138 by SCP protocol but it failed. The error message on the switch as below: %Error writing scp://user:password@192.168.1.1/...
schumaku
Dec 05, 2019Guru - Experienced User
Of course, SCP is workable on ReadyNAS OS6 systems. It's not a dedicated service, much more it's a default called ssh program. Said that, you need to enable the shell access for the user account on the NAS. And be aware that you can't use (e.g. for testing) the admin user -. for ssh it would be root (but that's a no-go anyway, you don't want to store the root password e.g on a switch).
- ThonglinDec 05, 2019Aspirant
I would like to backup the cisco switch config to ReadyNAS 3138.
NAS IP: 192.168.1.1/24
User: cisco
Password: password
SSH is enable.
Allow shell acess on the user is enable.
The error message on the cisco switch as below:
SW-VLVT-LL-3#copy running-config scp://cisco:password@192.168.1.1/Configurations/SW-Test.txt
Address or name of remote host [192.168.1.1]?
Destination username [cisco]?
Destination filename [Configurations/SW-Test.txt]?
Writing Configurations/SW-Test.txt
%Error writing scp://*****:*****@192.168.1.1/Configurations/SW-Test.txt (Undefined error)The following backup is including path VOLUME but still not working
SW-VLVT-LL-3#copy running-config scp://cisco:password@192.168.1.1/VOLUME/Configurations/SW-Test.txt
Destination filename [VOLUME/Configurations/SW-Test.txt]?
Writing VOLUME/Configurations/SW-Test.txt
%Error writing scp://*****:*****@192.168.1.1/VOLUME/Configurations/SW-Test.txt (Undefined error)Any idea of this issue?
- schumakuDec 06, 2019Guru - Experienced User
Not sure from where you have the idea that /Configurations or /VOLUME/Configurations/ should be used as destination folders.
ssh, scp or ftps on a ReadyNAS are not pointing to a virtual root, much more it's all referring the effective root file system. To bring the data into a shared folder (as configured for share access) use /data/[sharedfoldername]/ or for the user home folder use /home/[username] as the destination folder.
- ThonglinDec 06, 2019Aspirant
When I create a new share it automatic create under /VOLUME/....
I using a user: vbackup to send the cisco config file to NAS.
Please see picture in attached.
Can you give me the instruction of using SCP backup to the NAS?
Best Regards,
Thonglin
