Sandshark
Sep 08, 2021Sensei
Scrub slowed to a crawl, then locked up system.
My RN4200V2 backup system running OS6.9.6 used to complete a scrub in a bit over a day. It contained 12x3TB HGST enterprise drives in XRAID/RAID5 at that time. A couple months ago, I replaced 4 of ...
Sep 08, 2021Guru - Experienced User
smartctl -x might give you some info on whether any new errors are happening with the disks.
You might also consider pausing the scrub again, and running some disk test with smartctl.
- SandsharkSep 09, 2021Sensei
Well, it did the same thing again at the same point, as I was afraid it would, so I aborted and will have to start running some tests on the drives.
- SandsharkSep 14, 2021Sensei
OK, so initiating a drive self-test via the GUI found no errors (as also verified via smatrctl -x output).
I did do some "poking around" in the BTRFS structure and noticed this:
root@RN4200B# btrfs filesystem df /data Data, single: total=27.45TiB, used=26.11TiB System, RAID1: total=32.00MiB, used=3.84MiB Metadata, RAID1: total=17.00GiB, used=14.18GiB Metadata, DUP: total=1.00GiB, used=549.25MiB GlobalReserve, single: total=512.00MiB, used=0.00B
The metadata for the added MDADM layer is separate in DUP format, not RAID1 with the rest. I'm not sure if that has anything to do with it, but I don't think it's good. The BTRFS wiki gives this warning: If the metadata is not converted from the single-device default, it remains as DUP, which does not guarantee that copies of block are on separate devices. If data is not converted it does not have any redundant copies at all.
Now, since the "device" is an MDADM RAID, not a single drive, that's probably not quite so dire. But it also doesn't seem, right. It's been a long time since I had a volume with unequal drive sizes, and I may not have even noticed this then, so I don't know if it's normal for a vertically expanded ReadyNAS. I do have a RAID5 of 12 drives, done by creating it in FlexRAID (with all drives 3TB at that time) and then switching to XRAID, so maybe it would be different in another case. XRAID likes a 12-drive unit to have RAID6.
I also looked back, and I did do a balance and scrub right after I added the last of the larger drives, and that scrub only took 26 hours. I don't know for sure if both metadata sections contained data at that point, though the balance should have caused that to be the case.
Any thoughts on whether a btrfs balance start -mconvert=raid1 would help, or how it might affect future expandability? I did do that on my main NAS when I manually vertically expanded a volume that's in FlexRAID, but I don't have to worry there about maintaining XRAID expandability. At the time I did that on the manual expansion, I didn't realize that the newly added layer's metadata being in DUP format was "normal".
The next step would be to start pulling drives and testing them in a PC, a long time for my backup system to be down with 8x3TB and 4x6TB drives to test or to destroy the volume and re-create, hoping whatever is causing the prbolem either goes away or shows up with a vengeance.
- StephenBSep 14, 2021Guru - Experienced User
I do have two RAID groups on my primary NAS, and I see
root@NAS:~# btrfs fi df /data Data, single: total=14.47TiB, used=13.99TiB System, RAID1: total=32.00MiB, used=1.62MiB Metadata, RAID1: total=15.00GiB, used=13.16GiB GlobalReserve, single: total=512.00MiB, used=0.00B
So only one metadata line for the volume, even though there are two RAID groups.
