jukkaforss
Jul 07, 2013Tutor
Scrub Volume Command failed
Hi, I started scrub many days ago, it still says that it is running: Scrubbing in progress: 21.97% completed. Now I try on stop it, I get error, red cross: There was an error in volumes. ...
jukkaforss
Jul 09, 2013Tutor
Got it started again !!
root@readynas:~# btrfs scrub status /data
scrub status for 7c0b297e-1b89-4fbf-8e56-4d4caee95803
scrub started at Wed Jul 3 15:15:10 2013, running for 7586 seconds
total bytes scrubbed: 493.54GB with 0 errors
root@readynas:~# btrfs scrub cancel /data
ERROR: scrub cancel failed on /data: not running
root@readynas:~# btrfs scrub start /data
scrub started on /data, fsid 7c0b297e-1b89-4fbf-8e56-4d4caee95803 (pid=23962)
scrub started at Tue Jul 9 10:04:35 2013, running for 45 seconds
total bytes scrubbed: 2.60GB with 0 errors
