jukkaforss
Jul 07, 2013Tutor
Scrub Volume Command failed
Hi, I started scrub many days ago, it still says that it is running: Scrubbing in progress: 21.97% completed. Now I try on stop it, I get error, red cross: There was an error in volumes. ...
Jedi_Knight
Aug 14, 2013Tutor
wagon wrote: Greetings,
After months and months of hesitation have I finally chosen the Readynas 102 + 1 WD Red 2TB . And after a day of use I encounter my scrub process locked in 4.24% for hours. Apparently another user was uploading when I command the OS to start scrubbing. Dunno how relevant this info is but I had to physically reset it. And also I don't know if my data is intact. Thus my first post here.
It seems you could discover how to get it started again but frankly I'm not able to understand your explanation. Any tips for a rookie?
Thank you in advance.
Which firmware version are you using?
