jukkaforss
Jul 07, 2013Tutor
Scrub Volume Command failed
Hi, I started scrub many days ago, it still says that it is running: Scrubbing in progress: 21.97% completed. Now I try on stop it, I get error, red cross: There was an error in volumes. ...
Wagon
Aug 16, 2013Aspirant
StephenB wrote: First I'd run vendor diags (in this case Lifeguard) on the drive. You'd do this in a PC (using a USB enclosure or adapter is fine).
If it passes, I would engage Netgear support (support.netgear.com if your 90 days phone support is up).
If it fails, try returning it to the seller first, since they would exchange it for a new drive. If it is too late for that, contact WDC, they will provide a re-certified replacement.
Wow your procedures seemed so serious and laborious that a factory reset didn’t sound so drastic anymore to me. So I did it. And it seems ok. No more scrubs there for now. :wink:
Now in a X-Raid disc is it superfluous to use the scrub procedure? And if not, how often?
Thank you again Stephen!
