jukkaforss
Jul 07, 2013Tutor
Scrub Volume Command failed
Hi, I started scrub many days ago, it still says that it is running: Scrubbing in progress: 21.97% completed. Now I try on stop it, I get error, red cross: There was an error in volumes. ...
Wagon
Aug 16, 2013Aspirant
Nice, thank you!
I had scrubbed before and no problems. This last time the only difference is that another user was uploading files while the procedure was started and the NAS lost connection afterward. So I supposed that uploading new data while checking it could have been the cause.
But I'm willing to check the disk integrity of course. Is it possible to look at the SMART status via browser? Or do I need to install RAIDar?
This server wasn't bought in the same place as the hard disk so it would be complicated to relate it to the support which, btw, has been so strongly criticized here and elsewhere that frankly I'm afraid to contact. Thankfully I intend to be a 'light' user :p
Best regards.
Best regards.
