jukkaforss
Jul 07, 2013Tutor
Scrub Volume Command failed
Hi, I started scrub many days ago, it still says that it is running: Scrubbing in progress: 21.97% completed. Now I try on stop it, I get error, red cross: There was an error in volumes. ...
Sobal
Feb 23, 2014Aspirant
I have the same problem (new ReadyNAS 104 fw 6.1.6).
Do you have any idea how to force it to cancel?
root@schemnas:~# btrfs scrub status /data
scrub status for 93255340-2c1f-457a-90ab-8388c735651f
scrub started at Sun Feb 23 21:12:27 2014, running for 873 seconds
total bytes scrubbed: 98.28GiB with 0 errors
root@schemnas:~# btrfs scrub cancel /data
ERROR: scrub cancel failed on /data: not running
root@schemnas:~# btrfs scrub resume /data
ERROR: scrub is already running.
To cancel use 'btrfs scrub cancel /data'.
To see the status use 'btrfs scrub status [-d] /data'.
root@schemnas:~# btrfs scrub start /data
root@schemnas:~#
Maciek
root@schemnas:~#
Maciek
