jukkaforss
Jul 07, 2013Tutor
Scrub Volume Command failed
Hi, I started scrub many days ago, it still says that it is running: Scrubbing in progress: 21.97% completed. Now I try on stop it, I get error, red cross: There was an error in volumes. ...
nasischijf
Sep 13, 2014Aspirant
Black Duck wrote: I too have exactly the same problem.
Update:
Found this http://bugzilla.kernel.org/show_bug.cgi?id=66151 which pretty much describes the problem.
Found the offending status file in /var/lib/btrfs.
Checked that no 'btrfs scan' task was running (htop).
(After backing up my data), I deleted the status file. That cleared the 'scrub in progress' status from frontview, and ran a new scrub.
After scrub finished ran 'cat' command on the status file to confirm all was okay.
Thanks, this solved the problem in my devicd!
