hoppo1
Jul 26, 2014Guide
Scrubbing wont complete stuck at 12.68%
Hello, I have a readynas 104 6.1.8 with a single 2tb disk. The scrubbing is sat at 12.68% and wont move on. In root I type the following- root@:~# btrfs scrub status /data scrub status for 3f8...
hoppo1
Jul 27, 2014Guide
For info I logged with support who's answer was to replace the disk as not on the supported list :roll: :roll: easy way out Netgear......
Fortunately being a techie I sorted myself.
The status file lives in /var/lib/btrfs
root@:/var/lib/btrfs# ls -l
total 4
-rw------- 1 root root 413 Jul 27 20:52 scrub.status.3f816cf0-4849-4982-a733-54aa1e93559b
As this doesn't have an associated pid it sort of in limbo. So it was a simple case of moving it out of this folder and then starting the job again.
root@:/home# btrfs scrub start /data
scrub started on /data, fsid 3f816cf0-4849-4982-a733-54aa1e93559b (pid=9568)
root@:/var/lib/btrfs# btrfs scrub status /data
scrub status for 3f816cf0-4849-4982-a733-54aa1e93559b
scrub started at Sun Jul 27 20:48:34 2014, running for 451 seconds
total bytes scrubbed: 47.25GiB with 0 errors
Hopefully this will complete this time. I'm *hoping* that it previously failed as I was messing around as this is new I'm loading it up with data and testing and might have rebooted a few times after setting it running !
total 4
