carlocki
Feb 04, 2022Luminary
second usb hdd not always connect (quite never)
Hi Friend not always my second external usb drive is connect to the nas the first one on rear port 1 work the second on rear port2 not always. I backuped on both sucefully
- Feb 08, 2022
[SOLVED]
i FORMATED THE HDD DIRECTLY INSIDE THE NAS AND NOW EVERY RESTART HAS NO ISSUES
carlocki
yes it works with the two adapters in two different sockets
Sandshark
Feb 05, 2022Sensei
If you swap the drives, does the problem follow the drive or the port?
- carlockiFeb 05, 2022Luminary
sometimes they work sometimes they not
right now I played with socket and adapter of hdd bck2_R to have this
- carlockiFeb 06, 2022Luminary
every restart I miss the second usb, IT is so frustratring. I need to move the adapter but this version has a light so it works so the hdd needs to be rasterted to be revelead
- carlockiFeb 08, 2022Luminary
[SOLVED]
