carlocki
Feb 04, 2022Luminary
second usb hdd not always connect (quite never)
Hi Friend not always my second external usb drive is connect to the nas the first one on rear port 1 work the second on rear port2 not always. I backuped on both sucefully
- Feb 08, 2022
[SOLVED]
i FORMATED THE HDD DIRECTLY INSIDE THE NAS AND NOW EVERY RESTART HAS NO ISSUES
carlocki
Jun 28, 2024Luminary
his is the real last issue that i have
with just one hard drive
i have to unplug it and remove usb to restart the connection.
it is the last issue of all the entire system
Jun 28, 2024Guru - Experienced User
I'm not sure I understand what you mean by "restart the connection".
Are you saying you need to do this after you boot up in order to access the data on the drive?
Or something else?
