mkopel
Aug 27, 2011Aspirant
Select Folder Dialog Box is blank?
I am trying to set up some backups using frontview but everytime I try to use the Browse button to select the source or destination path is just comes up blank. On safari I can hit cancel, but in fire...
mkopel
ahh, the problem was that the script was running so slowly that I did not know it was doing anything. Perhaps it should only traverse the file structure tree if a folder is opened in the dialog, instead of caching the entire file structure before drawing anything.
also, I found that just using spaces in the interface was the way to go.
