Zonker
Aug 26, 2017Apprentice
Set up RN102 as JBOD that Span
When I set up two disks as JBOD with X-Raid turned off, ReadyNas will manage each hard drive as a separate logical volume. Is there a ReadyNAS option to allow Spanning that will will combine both o...
Zonker
yeah, but at least I could recover 1 of the disks files. In RAID 0 all I would have is half the file on 1 disk, so I would lose everything.
If anyone knows where I can find instructions on spanning JBOD I would appreciate it.
Thanks,
Aug 28, 2017Guru - Experienced User
That would not be guaranteed, particularly as the volume gets older. There is no striping, but files will end up on both disks, and metadata could end up on one drive, but the datablocks on the other one. If you want maximum recoverability, use two volumes (one for each disk), and put some shares on each. Backups are of course better than hoping that data recovery will work.
I just checked the software manual, and it says that jbod requires one disk per volume. Though you could try it I guess (sometimes the manual isn't quite right). You'd destroy your current volume (uninstall your apps first), and then create a new one.
- ZonkerAug 28, 2017Apprentice
Thanks Stephen. I have tried everything and cannot fina a way to Span JBOD in ReadyNAS 6.8.. I think the only optioin is RAID 0 and then backup to USB attached drives.
If anyone from Netgear technical support could chime in here and confirm this I would appreciate it. To have to pay for a support case for them to tell me "no it can't" seems wrong.
Thanks
