Newsat11
Apr 24, 2016Luminary
Setting up cron jobs on OS6
I am looking for help setting up a cron job on OS6. I am using Moodle, which requires a cron job to keep it running effeciently, and i do not feel like logging in everyday to run the command manually...thus the post. Can anyone tell me if the OS6 supports cron jobs through the web interface? If not, will I be able to set the up through SSH in a typical fashion, or will I need some kind of alterations? Any help would be greatly appreciated.
- Dewdman42VirtuosoI was under the impression /etc/cron.d is handled differently then crontab.
The jobs I put there are not running - mdgm-ntgrNETGEAR Employee RetiredYou would need to use SSH for this.systemd timers are preferable to cron jobs though you can setup cron jobs using SSH. Consider the warning about enabling SSH access before you enable it.
- Newsat11Luminary
Thanks for the help. I have been using SSH for a while, so it is a little late to worry about SSH. I installed some third party software that required me to change permissions and ownership on certain directories. Can you give me more information on systemd timers? Moodle provides a particular cron job via CLI, and I don't know enough about timers to now how it translates.
There is lots of info available if you search for it in a search engine and you can also see some timers already running on the NAS.
