Theresias
Sep 15, 2015Tutor
Setting up RAID6 and RAID0 side-by-side?
Hey guys, I've tried to find an answer for this but wasn't able to myself - if this has been answered before, please don't hesitate to let me RTFM. :) The question is pretty simple, can RAID6 and...
Sep 15, 2015Guru - Experienced User
I'm not a fan of spanning RAID-0 either. As mgdm says, xraid with dual redundancy will give you the same total space in a single 16 TB volume.
If the 2x2TB drives are already installed and using xraid, then you can expand to 4x6TB+2x2TB dual redundancy.
If the 4x6TB drives are already installed, then you can't add the 2TB drives to that array. You'd either need to switch to flexraid and create 2 2TB jbod volumes (safer than raid-0), or create a new volume/restore data from backup.
Theresias
Sep 15, 2015Tutor
Thanks guys for your input. At this point all drives are blank.
Stephen, I am slightly confused now. Per [url=http://www.netgear.com/images/pdf/WP_XRAID2vsFlexRAID%20_12May14.pdf]this NTGR document[/url], JBOD can only be configured for one disk (even though I understand that the concept of JBOD isn't to have just one drive). I had hoped that document was wrong/misleading, but would have settled with RAID0 instead but as you JBOD would be my favorite.
The VOLUME1 (RAID6) is for storage only and I really want that 2 disk failsafe (had 2 disks fail while I was out of town for a few weeks a while back... lost a bunch of data in the process - call me paranoid). The VOLUME2 (RAID0 or preferrably JBOD) is just a storage on the NAS for moving data around, the data in question is backed-up elsewhere - let's call it a TEMP/TRANSFER-VOLUME. So I am not concerned about the missing redundancy on that volume.
Again, thanks for your input - I'll try setting up the 4x6TB RAID6 and then the 2x2TB JOBD per your suggestion. Will report back.
- StephenBSep 15, 2015Guru - Experienced User
You can create up to four volumes with FlexRaid, and I have multiple JBOD volumes two OS6 NAS (and a duo v1).
JBOD won't work if iyou have a share that is too large to fit on a single drive, and RAID-0 sometimes is a bit faster. But its fragile, so it is very important to maintain backups if you use it.
