tommychan
Aug 07, 2015Aspirant
Setting up Roaming Profiles
Hi everyone, I am facing a problem that I am not able to have AD users to connect to a Roaming Profile, that a path is pointing to a ReadyNAS share. When I login to the AD Windows gives me a mess...
mdgm-ntgr
Aug 07, 2015NETGEAR Employee Retired
You may be better off using iSCSI and sharing the files on the LUN from your server.
You can get into some issues with smb signing and how profiles expect ntfs permissions to work.
tommychan
Thanks for the solution. I have come up with a follow up question regarding on using iSCSI. As I am currently teaming up the network adapters of the NAS to a managed switch, while the connection between the switch and Windows Server terminal is a single 1GbE connection, would I need to worry about the lower data transfer rate due to the bottleneck of the connection as well as the performance hit of the services running at the Windows Server? My goal is to setup a AD with 20 users and so there will be 20 user profiles. Thanks
