camelxx
Nov 28, 2014Aspirant
Setup for 314 with WD Red 6 tb
I'm considering picking up the 314 4 bay with 4x 6tb WD red drives. Couple of questions please:
1) for XRaid2, will I have 18 gigs avail. as 1 volume?
2) If I go for the 516, Can I initially build with 4x6tb, and later add 2 more without limitations?
Any real advantage of going with 516 other than 2 more slots and better power supply?
Side note I was going to upgrade my ReadyNas Pro that has 6x2tb, but I think this is better solution by keeping that as is and getting 314. Am I missing something here?
Thanks in advance!
Thanks in advance!
- camelxxAspirantI only getting a "Device is offline, please wait" message from within Frontview.
meanwhile the 316 is SLOWLY resync ing. now at 3.5% after almost hour. - mdgm-ntgrNETGEAR Employee RetiredI guess you could try another factory default, go in and interrupt the sync and create a new volume. Should be no need to pull any disks.
- StephenBGuru - Experienced UserYour goal is RAID-6 correct?
So to expand on mdgm's procedure
switch to flexraid, and destroy the volume.
Then create a new volume (same name - data is the default), choosing raid-6.
This will of course delete any data on the NAS. - camelxxAspirantOkay, wow...thanks guys!! What a great support group/forum!!
So not sure what happened, but taking advice and restarting the Factory default worked right away, I was able to get to everything just as you all said I should see and do.
Bottom line, was able to interrupt, create a new volume with all the drives as RAID6, switched it back to XRAID and it's building just fine. Thanks again my friends!
