Neth
Mar 16, 2015Aspirant
Several problems with the NVX
Hi there! I have a ReadyNAS NVX running on firmware 4.2.27. Lately, i've started to get some issues. It all started when i decided on a new folder structure for my NAS. I created a new shared fol...
mdgm-ntgr
Mar 18, 2015NETGEAR Employee Retired
Just checked and the disk test passed. So looks like either bad RAM or some other hardware failure.
Are you comfortable with Linux shell commands? If so, you could try checking to see if the volume will mount in Lubuntu using some commands I can give you, but use them at your own risk.
