atai1
Mar 30, 2015Aspirant
Share problem NV
Hello, I have a problem creating a new share on my NV. I have added a new volume and when I try to create a new share on this volume I can't then access from windows XP or 7. Anytime I try to map...
atai1
Apr 02, 2015Aspirant
unfortunatelly I have bad news
After this change on the set up I am no more able to select my music using Sonos.
I am also using a mediaplayer for see my movies and also this do not work any more.
But the very bad thing is if I try to go back to the previuos set up the systems do not work idem
Can somebody explain me what is goin on?
On many years of use of this NAS i never had problem using the Security mode on share.
Sonos is fixed now but for the mediaplayer this is the answer from the forum of the vendor:
"The HiMedia video player is only compatible with anonymous shares"
