atai1
Mar 30, 2015Aspirant
Share problem NV
Hello, I have a problem creating a new share on my NV. I have added a new volume and when I try to create a new share on this volume I can't then access from windows XP or 7. Anytime I try to map...
atai1
Apr 03, 2015Aspirant
This is the message that I have from the mediaplayer vendor:
(please note if you use XBMC/KODI to play files from SMB network, the SMB network should have no User ID and Password.)
Do you think there is a way to handle this with my NV?
The very strange thing is that everything was working perfect until I switched the securuty mode except for the volume inserted (but it's empty at the moment)
It depend by the FW version?
If yes it's possible to reinstall an old FW version?
