atai1
Mar 30, 2015Aspirant
Share problem NV
Hello, I have a problem creating a new share on my NV. I have added a new volume and when I try to create a new share on this volume I can't then access from windows XP or 7. Anytime I try to map...
Apr 03, 2015Guru - Experienced User
If you set up the share to "everyone" access in user mode, then no password is needed. This works perfectly for me with several players (WDTV Live, EVA9150, NTV550).
You shouldn't need to go back to the old mode, what you need to do is fix your permission.
Perhaps you can tell us your settings for one of the media shares?
