fooboo
May 20, 2016Star
Shares disappeared after restarting Frontview manually.
ReadyNAS NV (I know, I know) running latest firmware. Been a faithful user for years. Somewhere between restarting frontview and nfs-kernel-server via command line (in an attempt to tighten ...
mdgm-ntgr
May 20, 2016NETGEAR Employee Retired
What's the output of the following?:
# df -h
# df -i
- foobooMay 20, 2016Star
nas01:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 343M 1.6G 18% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 5.4T 4.6T 825G 86% /c
nas01:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 128000 8058 119942 7% /
tmpfs 31583 1 31582 1% /USB
/dev/c/c 182812672 619305 182193367 1% /c
As mentioned, I don't think space is the issue (even though /c is getting a little full)
Here is the output of ls.
As you can see the Shares.conf are showing as zero. I'm wondering if adding a new share will help populate those files sufficiently that I can manually add the other old shares back in. Obviously, I want to avoid deleting those shares...
nas01:/etc/frontview# ls -l samba/ apache/
apache/:
total 96
lrwxrwxrwx 1 admin admin 7 May 19 14:09 1987cbba.0 -> new.pem
lrwxrwxrwx 1 admin admin 32 Nov 16 2013 a725456d.0 -> /etc/frontview/apache/apache.pem
drwxr-xr-x 2 admin admin 16384 Apr 8 2009 addons
-rw------- 1 admin admin 1555 Nov 16 2013 apache.pem
-rwxr--r-- 1 admin admin 9079 May 19 16:47 httpd.conf
-rw-r--r-- 1 admin admin 3025 May 19 14:07 new.pem
-rw------- 1 admin admin 0 Jun 14 2006 Ports.conf
-rw------- 1 admin admin 0 May 19 16:26 Shares.conf
-rw------- 1 admin admin 0 May 19 16:26 Shares.conf.1
-rw-r--r-- 1 admin admin 301 May 15 2006 ssleay.cnf
-rw------- 1 admin admin 140 May 18 13:01 Virtual.conf
samba/:
total 256
drw-rw---- 2 admin admin 16384 Jan 30 2008 addons
-rw-rw---- 1 admin admin 0 May 19 16:26 Shares.conf
-rw-rw---- 1 admin admin 294 May 19 16:26 Shares.conf.admin
-rw-rw---- 1 admin admin 294 May 19 16:26 Shares.conf.administrator
-rw-rw---- 1 admin admin 0 May 19 16:26 Shares.conf-sav
-rw-rw---- 1 admin admin 75 Apr 24 2012 smb.conf.CIFSFS
-rw-rw---- 1 admin admin 54 Mar 4 2005 smb.conf.OS2
-rw-r----- 1 admin admin 125 Apr 24 2012 smb.conf.OSX
-rw-rw---- 1 admin admin 54 Mar 4 2005 smb.conf.Samba
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.UNKNOWN
-rw-rw---- 1 admin admin 88 Sep 24 2013 smb.conf.Vista
-rw-rw---- 1 admin admin 120 Jun 5 2009 smb.conf.WfWg
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.Win2K
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.Win2K3
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.Win95
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.WinNT
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.WinXP
-rw-rw---- 1 admin admin 55 Apr 24 2012 smb.conf.WinXP64
Digging around, I see that others have complained about possibly the same issue but appears to be no resolution...
https://community.netgear.com/t5/Using-your-ReadyNAS/Shares-disappeared-after-reboot/td-p/895106
