fooboo
May 20, 2016Star
Shares disappeared after restarting Frontview manually.
ReadyNAS NV (I know, I know) running latest firmware. Been a faithful user for years. Somewhere between restarting frontview and nfs-kernel-server via command line (in an attempt to tighten ...
fooboo
May 20, 2016Star
Here is the output of ls.
As you can see the Shares.conf are showing as zero. I'm wondering if adding a new share will help populate those files sufficiently that I can manually add the other old shares back in. Obviously, I want to avoid deleting those shares...
nas01:/etc/frontview# ls -l samba/ apache/
apache/:
total 96
lrwxrwxrwx 1 admin admin 7 May 19 14:09 1987cbba.0 -> new.pem
lrwxrwxrwx 1 admin admin 32 Nov 16 2013 a725456d.0 -> /etc/frontview/apache/apache.pem
drwxr-xr-x 2 admin admin 16384 Apr 8 2009 addons
-rw------- 1 admin admin 1555 Nov 16 2013 apache.pem
-rwxr--r-- 1 admin admin 9079 May 19 16:47 httpd.conf
-rw-r--r-- 1 admin admin 3025 May 19 14:07 new.pem
-rw------- 1 admin admin 0 Jun 14 2006 Ports.conf
-rw------- 1 admin admin 0 May 19 16:26 Shares.conf
-rw------- 1 admin admin 0 May 19 16:26 Shares.conf.1
-rw-r--r-- 1 admin admin 301 May 15 2006 ssleay.cnf
-rw------- 1 admin admin 140 May 18 13:01 Virtual.conf
samba/:
total 256
drw-rw---- 2 admin admin 16384 Jan 30 2008 addons
-rw-rw---- 1 admin admin 0 May 19 16:26 Shares.conf
-rw-rw---- 1 admin admin 294 May 19 16:26 Shares.conf.admin
-rw-rw---- 1 admin admin 294 May 19 16:26 Shares.conf.administrator
-rw-rw---- 1 admin admin 0 May 19 16:26 Shares.conf-sav
-rw-rw---- 1 admin admin 75 Apr 24 2012 smb.conf.CIFSFS
-rw-rw---- 1 admin admin 54 Mar 4 2005 smb.conf.OS2
-rw-r----- 1 admin admin 125 Apr 24 2012 smb.conf.OSX
-rw-rw---- 1 admin admin 54 Mar 4 2005 smb.conf.Samba
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.UNKNOWN
-rw-rw---- 1 admin admin 88 Sep 24 2013 smb.conf.Vista
-rw-rw---- 1 admin admin 120 Jun 5 2009 smb.conf.WfWg
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.Win2K
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.Win2K3
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.Win95
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.WinNT
-rw-rw---- 1 admin admin 55 Mar 4 2005 smb.conf.WinXP
-rw-rw---- 1 admin admin 55 Apr 24 2012 smb.conf.WinXP64
fooboo
May 20, 2016Star
Digging around, I see that others have complained about possibly the same issue but appears to be no resolution...
https://community.netgear.com/t5/Using-your-ReadyNAS/Shares-disappeared-after-reboot/td-p/895106
- StephenBMay 20, 2016Guru - Experienced User
I am not seeing your shares in your ls output, just your user account folders.
If the shares are there, have you backed them up?
- foobooMay 20, 2016Star
Please see the link above for similar problems experienced by others. It looks like the shares and users somehow get confused and dumped into /etc/passwd.
The initial ls screenshot shows /c which are just the shares. I have blanked out the user account names (blue stuff). The shares are still there as of now and no, the shares are not backed up right now and therefore I'm hesitant to try to, a) delete the shares showing up as account names and b) try to create a new share to try to manually determine the format necessary to recreate the existing shares.
I've got another NAS coming (hopefully by Monday) so my plan is to back up to that first via rsync.
