bengsig
Aug 24, 2024Aspirant
Shares lost from admin page
My ReadyNAS 212 has lost all shares and I only see: I have looked at other articles mentioning the same, and I have checked I am not running out of space. And also, when I ssh to the system, ...
- Aug 25, 2024
bengsig wrote:
However, clicking update, I am told I am on the latest so I cannot upgrade to 6.10:
First of all, you are seeing that message only because you've chosen to set "Check for Updates" to "long term stable" on the system->settings->update page. You can just change that setting to "stable" and you will get 6.10.10
However, if you have apps installed, then I suggest stopping at 6.10.9. 6.10.10 removes the ability to install apps from the web admin apps page.
You can download 6.10.9 from here:
Extract the firmware from the arm zip file, and then install it manually (system->settings, then press the "install firmware" button in the middle of the page.
Aug 24, 2024Guru - Experienced User
If you do not have a backup of the files, then it would be good to make one before proceeding further.
Have you checked for a full OS partition?
- SandsharkAug 24, 2024Sensei
There is a script that can usually fix that. But before you run it, you need to be sure you don't have a full OS partition, as the script needs space there to operate and running it without that space available can make matters worse. And you need to make sure you have a backup in case what the script tries to fix isn't your issue.
- bengsigAug 25, 2024Aspirant
As I also wrote initially, I am not running out of space:
so the root partition has ample free space. I also heard about the script mentioned, and would very much like to have it.
Thanks!
- StephenBAug 25, 2024Guru - Experienced User
This was written by a Netgear developer for support use some years ago. Unfortunately, the last time I checked, the certificate had expired.
However, you can still run it using these steps:
# cd // # wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh # chmod +x ./share_lun_ui_fix.sh # ./share_lun_ui_fix.sh
- May 30, 2016Retired_Member
