hawke84
Mar 06, 2015Tutor
Shares within a Share
Hi all, im really new to readynas and btrfs. My old NAS had a file structure Media/Tv Media/films I had Media as one share TV as another and Films as the final so I could direct into the fo...
Mar 06, 2015Guru - Experienced User
You are totally wrong on that. You can absolutely do it.
hawke84 wrote: for anyone else searching this, it doesnt work with SMB shares, cant connect directly with admin credentials, at least through windows.
Try closing all windows connections to the NAS and then opening a command box (e.g., enter "cmd" in the search bar under the windows icon).
Then enter
net use * /delete
net use t: \\nasname\C /user:admin adminpassword
Portions in italics are placeholders.
That should map the C volume to a t drive letter.
There are other ways (including entering the NAS credentials into the windows credential manager).
