xtrips1
Oct 12, 2011Aspirant
Simple question: need answer fast PLZ
Hello, On a ReadyNAS Pro, does the Factory default option resync the drives? This is not documented anywhere. And I have 6 X 3TB HDDs, so it will take days. Is there any way I can reset: - user...
TeknoJnky
Oct 12, 2011Hero
xtrips wrote: Hello,
a factory default erases everything, data and config, and does a resync to generate the nessecary parity data.
I would not expect it to take days, perhaps 8 to 24 hours depending on the speed of the drives and whether you're trying to read/write during the resync.
