digitaljunkie1
Oct 10, 2011Aspirant
Single iSCSI taret & 2 initiators...
I have a ReadyNAS 2100 in operation that has the following configuration... 1 x SMB share mounted on a SBS2K8 box 1 x iSCSI Target with a single 2TB LUN which has Access Control Enabled The i...
TeknoJnky
Oct 10, 2011Hero
If you need to share data that is on an iscsi volume, you should mount the iscsi volume with a single server, then share the files out on that server via whatever protocol (cifs/nfs/atalk, etc).
