BalROCK
Oct 31, 2016Aspirant
Slow stransfer speed over SMB and FTP
As in the topic. Maximum for both protocols is around 10 MB/sec (stable). Checked with Windows 7 x64, addtionally with nastester 1.7 OS 6.6.0 AV - On/Off (doesn't matter), currently Off BitRotP...
- Nov 01, 2016
Ok, i run some tests (some of them I should do as first wave :(). From all computers in my lab, Win XP, 7 x64, x86, 10, Vista - 10 MB/s. I once again connected my computer with NAS directly and ... yuupi - transfers - 50-80 MB/s. So, the problem is clearly at the network. The infrastructure I can check - all 1Gb/s. There must be a bottleneck hardware I can't see. Or, my Net Administator set 100Mb/s cap for all users, since transfer with other servers ( e.g. Win 2008 Server) also can not exceed 10Mb/s.
I will talk with him tommorow and give an info where to look. So, StephenB - your original idea about network speed was good :)
BalROCK
You might be right about IPv6, currently i have another issue, I accidentally changed MTU from 1500 to 300 and no I can not log to admin page and files via SMB. But, I can access them via FTP ? WTF? :cry: Do I have to reset to default the entire unit ?
Oct 31, 2016Guru - Experienced User
An OS reinstall should resolve it. The IP configuration will end up factory default (DHCP), and the admin password reset back to password. Other settings shouldn't be changed, and the data should be preserved.
The procedure is described on pages 44-45 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
- BalROCKOct 31, 2016Aspirant
thx for the suggestion, I was already preparing myself and NAS for USB backup restore ... something process, when I suddently came with a better solution (the only prerequisite was that knew I set MTU for 300). I have changed my own computer mtu setting for 300 (described here http://networking.nitecruzr.net/2007/11/setting-mtu-in-windows-vista.html) and when I connected my computer and NAS directly (after setting the same subnetwork and ip's at the same network etc) I was finally able to access admin page and change the f**king MTU settting. Phew ... :)
Back the original problem, what should be mean transfer from 1 ethernet connection if the entire net infrastructure is 1Gb/s - 10-11 Mb/s looks too low for me :( About these Switch logs/data etc. What might be helpful :) I can provide you with almost anything :)
- StephenBOct 31, 2016Guru - Experienced User
disable ipv6 on the NAS first. If the PC has both wifi and ethernet, try disabling wifi, just to make sure you are using the ethernet path.
Do you have the ReadyCloud client installed on the PC?
I've disabled IPv6 on NAS, no difference. WiFi is in fact turned on but not connected to any network (tummorow I'll check if it makes any difference). About ReadyCLOUD - I wasn't planning to use it (many different users with relatively commplicated shared folders access, Read only, groups etc) but, At least for testing purposes, Ill check it tommorow. I've already changed Ethernet functions like Green ethernet etc, no difference. Tommorow I will check also if the same problem is on Xp, Vista computers.
