ssjoholm
Oct 24, 2013Aspirant
SMART self-assessment test
Hi, My fourth disk did fail, so I did change it for a new and fresh one. But since the change I have started to get nightly event that the disk4 (which was swapped) does not pass the SMART self-ass...
ssjoholm
Oct 27, 2013Aspirant
Hi,
Thanks. Will replace.
The info about disk3 is here;
SMART Information for Disk 3
Model: ST2000DL003-9VT166
Serial: 5YD7WYN8
Firmware: CC3C
SMART Attribute
Spin Up Time 0
Start Stop Count 19
Reallocated Sector Count 0
Power On Hours 8625
Spin Retry Count 0
Power Cycle Count 19
Runtime Bad Block 0
End-to-End Error 0
Reported Uncorrect 0
Command Timeout 2
High Fly Writes 0
Airflow Temperature Cel 40
G-Sense Error Rate 0
Power-Off Retract Count 18
Load Cycle Count 19
Temperature Celsius 40
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Head Flying Hours 116861765165489
Total LBAs Written 2983353308
Total LBAs Read 964980276
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 2125
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
Sebastian
Serial: 5YD7WYN8
Firmware: CC3C
SMART Attribute
Spin Up Time 0
Start Stop Count 19
Power On Hours 8625
Spin Retry Count 0
Runtime Bad Block 0
End-to-End Error 0
Command Timeout 2
High Fly Writes 0
Load Cycle Count 19
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 2125
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
Sebastian
