VicMovieBuff
Nov 15, 2016Aspirant
Smart Tv has stopped playing movies from my ReadyNas
HI, Last Night i wanted to watch a movie from my readyNas on my Samsung Smart Tv and it told me there were no movie files on the server, yet in my TV shows folder it showed all of those no problems....
brentm
Jan 09, 2017Aspirant
ReadyDLNA
Jan 09, 2017Guru - Experienced User
Perhaps double-check that DLNA is enabled in the media shares, and then do a manual scan from system->settings.
- brentmJan 10, 2017Aspirant
Hi StephenB
Thanks. I've just checked and DLNA was selected. I've also rescanned. Still not working . I noticed however that I could see my pictures but still no video or music.
- StephenBJan 10, 2017Guru - Experienced User
Did anything change on the NAS or your home network generally around the time it stopped working?
One other possibility is that some media file has an issue that is causing the media scanner to crash. That would explain why you see photos but nothing else. You could try turning DLNA off on all shares, and then creating a test share, copying a few music and video files that you know worked before. Then enable DLNA on just that test share, and scan again. Let us know if files will stream from the test share.
- brentmJan 11, 2017Aspirant
Hi StephenB
Thank you! Some success.
This evening a firmware upgrade came through. No change. I then took the steps you suggested (ie removing DLNA from existing shares, creating new shares with DLNA enabled and adding sample files to each new test folder) and this worked. I then re-enabled DLNA on existing shares and was still able to see the sample files - however adding new files resulted in new audio files being visible but not video files. I even deleted and re added the sample video file. Weird. Anyway I guess I will just repeat the process and put all files into new shares and see how it goes. Thanks very much for yours and everyone elses help.
