vmadan
Apr 13, 2017Aspirant
SMB disabled
I had been having a lot of issues with my ReadyNAS - initially I could not get a 'stable' file transfer for any sizable files using explorer (it would just hang after inactivity). However, it was at least working through the brower UI. Lately, even that stopped so I was left with no way to transfer files within folders on the NAS or externally.
Aside from un-installing/re-installing SMB services on my Windows 10 PC, I tried disabling the services not being used (i.e. AFP and NFS) as I only access through windows. This however automatically completely disabled SMB and since then I cannot get SMB back to enabled. It just doesn't stay green in the settings no matter what I try. I've tried re-installing 6.6.1 many times now, and even upgraded to 6.7.0 beta 4 but nothing seems to work.
Any help would be greatly appreciated.
Thanks a lot
- jak0lantashMentorIt's to confirm if that would make the backup option possible.
Do you have a backup of the NAS files?
- vmadanAspirant
no, unfortunately not - the NAS serves as a backup for all PCs and a media server
And even if I were to buy a large enough external USB3 HDD I don't know if the web UI interface is going to allow me to copy over the files anyway.
- jak0lantashMentor
Did you try booting the NAS in Volume Read Only mode via the Boot Menu?
