miogpsrocks
Sep 29, 2016Tutor
Software to Recover array from each Hard drive outside of Readynas system?"
Is there a recovery software that can rebuild an array from individual drives outside the Readynas system? I have a readynas NV+ V1 and the system is not booting. I have tested each drive and...
miogpsrocks
Sep 29, 2016Tutor
Do you know if using this software will prohibit it from being used in the readynas again?
I think these are " read only" and don't modify anything but I'm not sure.
Windows based seem easier than building a Linux machine however its nice to have options available.
Thanks.
Sep 29, 2016Guru - Experienced User
I think your best option is to back up all the data, since the NAS isn't even booting. Very likely you will end up with a factory reset.
- miogpsrocksSep 29, 2016Tutor
OK, I think this answerd my question. I psoted the question before I even saw this response.
So try the recovery software and backup the data BEFORE trying it on the machine. Great , Got it.
Thanks.
