viperhansa's avatar
viperhansa
Virtuoso
Oct 23, 2014
[SOLVED] 4.2.27 breaks PLEX and other apps on 4.x x86.
Hi all.
I upgraded my 4.x x86 to 4.2.27 and now several apps dont start or they say they start but they are not accessible.
PLEX for example says it starts but you cannot acces its admin page or access it from a plex client.
Can i downgrade back to 4.2.26 to see if that solves the problem? Do i loose any data if i do downgrade?
// Hans
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Plex still works for me.
    What add-ons do you have installed?
  • php5
    python
    couchpotato
    zabnzb
    transmission
    dropbox
    among others. can not access the list right now, cant even access frontview anymore.
    Was working perfectly up to the update.
  • now i got frontview to start.
    PÖEX says it starts but i cannor access "manage PLEX" hust returns a "page cannot be viewed".
    mdgm-ntgr
    Try installing some of the add-ons over the top of themselves e.g. PHP5 and Dropbox.
    Also do you have the latest version of the Plex add-on installed?
  • the other apps:
    istatd
    mysqlbackup
    phpmyadmin
    python 2.7
    readynas remote
    readynas photos
    sickbeard
    subsonic
  • newest PLEX, radiator.....
    Right now i am on a android pad in UK working. Will go back to sweden where i live tomorrow.
  • got this when upgrading to 4.2.27:
    Wed Oct 22 20:52:38 CEST 2014 =?utf-8?B?U3lzdGVtdXBwZGF0ZXJpbmdzc3RhdHVzIChIb2EtbmFzLVBybyk=?= : ReadyNAS-enheten har uppdaterats med en ny avbild för den fasta programvaran. (RAIDiator-x86 4.2.27)
    I also have updated php, dropbox... no change..
    php and sql seems to work fine since the webpage i run works.
  • Hi all and mdgm.
    Fix for the problem was:
    Uninstall dropbox client.
    re-apply radiator
    re-apply PLEX
    re-apply php
    Install Dropbox
    in that order...
    Problem solved! All seems to be working again.
    Thanks too mdgm for the pointers...
ProSupport for Business
