mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION]
I have been struggling with a few permissions related problems and would really appreciate some help:
This is my setup:
- User mode permissions
- A share called "lifepractice"
- Two users (one called "karen" and another called "mshields")
- Both users belong to the group "users"
I want both karen and mshields to both have rw access to files and rwx access to directories. The users are accessing the files via windows using CIFS. I don't want any other users to have any access to files or directories.
In the FrontView CIFS tab I have
- Default Access: Disabled
- Write-enabled users: karen,mshields
In the "Advanced CIFS Permission" tab I have set
- Automatically set permissions on new files and folders: true
- For both file and folders/directories I have set "Group rights:" to "Read/write" and "Everyone rights:" to disabled.
- Enable oplocks for this share: true.
In "Advanced Options" I have set:
- Share folder owner: lifepractice
- Share folder group: users
- Share folder owner rights: Read/write [actually this is greyed out]
- Share folder group rights: Read/write
- Share folder everyone rights: Disabled
- Grant rename and delete privileges to non-owner of files : True
The problems arise when one user creates a file and then another user edits that file and re-saves it. For example:
1) mshields creates the file test.doc
So far so good.
2) Next karen opens test.doc, changes it and saves
This is where things seem to go wrong.
Problem 1 - The owner of test.doc has changed from mshields to karen. Why does this happen? I thought that in Linux, when files are edited by a different user, the file will still retain the original user as the owner.
Problem 2 - Somehow the file has gained group execute permissions. How can I stop this happening?
Problem 3 - The ACLs for the file have an additional "user:mshields:rw-" entry and an additional "mask::rwx" entry that weren't present before the second edit of the file.
Problem 3 causes rsync to report errors when backing up to an NTFS USB drive (see the backup-related problem http://www.readynas.com/forum/viewtopic.php?f=31&t=44972&p=255310 that this causes).
I guess I can live with problems 1-3 if there's no alternative, but I really would like to avoid the rsync backup failures that are a consequence of Problem 3.
Thanks for any help.
This is my setup:
ls -l test.doc
-rw-rw---- 1 mshields users 24064 Sep 3 16:44 test.doc
getfacl test.doc
# file: test.doc
# owner: mshields
# group: users
user::rw-
group::rw-
other::---
So far so good.
ls -l test.doc
-rw-rwx--- 1 karen users 24064 Sep 3 16:48 test.doc
getfacl test.doc
# file: test.doc
# owner: karen
# group: users
user::rw-
user:mshields:rw-
group::rw-
mask::rwx
other::---
- mjw1Aspirant
ewok wrote:
Can you summarize what needs to be done?
The NTFS-3G developer is suggesting (here http://tuxera.com/forum/viewtopic.php?p ... 252#p22886) that we try his very latest release "2010.10.2AR.1" which is downloadable here:
http://www.tuxera.com/community/ntfs-3g-advanced/
I would suggest the following steps (a Sparc development environment running RAIDiator 4.1.6 is required for this):
1. Download the source tarball
2. Build using the "--enable-posix-acls" option
3. Post the ".deb" file in this thread so that I can also try it out
4. Install the resulting deb in your ReadyNAS Sparc development/test environment
5. Attach a NTFS formatted USB drive. Then in the root directory of the NTFS drive there must be a directory ".NTFS-3G" and within that directory a file called "UserMapping" (case is important) containing the line
::S-1-5-21-3141592653-589793238-462643383-10000
This tells NTFS-3G to handle ACL permissions. A reboot (or at least an unmount/mount) is required for this to take effect.
6. Create a file somewhere on your main "/c" ext3 partition (/tmp won't work since it isn't mounted with the ACL option)
touch test
7. Add an ACL to this file for any other user (except root) that is defined on your NAS
setfacl -m u:1234:rw- test
8. Unmount the NTFS drive
umount /USB/USB_HDD_1
9. Remount this time with debug enabled
ntfs-3g -o debug,acl,user_xattr,rw,sync,noatime,allow_other,blksize=4096 /dev/sda1 /USB/USB_HDD_1 2> /tmp/ntfg-3g.err
10. Copy the file with ACLs to the NTFS USB drive
cp -p test /USB/USB_HDD_1/
11. Unmount again (so that we stop getting debug messages in /tmp/ntfs-3g.err)
12. Post here any output/error messages that you see (e.g. Operation not supported) in this thread.
13. Post the contents of /tmp/ntfg-3g.err in this thread
It would also be very useful to repeat steps 5-11 in a ReadyNAS x86 Development environment running the latest released version of RAIDiator so we can see if the problem is limited to just the Sparc Readynas devices or also affects the x86 devices too.
As a very first step you could also run the test once on the Sparc Readynas before upgrading to the latest version of NTFS-3G just to confirm that you see the errors that I am currently seeing.
Thanks,
Mark - mjw1Aspirant
mdgm wrote:
They won't exchange it (ReadyNAS cost money to make, support etc.) but there is a loyalty program comingchirpa wrote: We are working on a loyalty program, which would give you a coupon code to save some money on an Ultra.
Keep an eye on the forum.
Thanks for pointing this out. It sounds interesting, but personally for my next device I'm holding off any upgrade until I can buy something that:
1) Supports USB3 and/or eSATA
2) Is rack-mountable and quiet enough to install in my media rack in the living room
3) Costs around $1000
4) 100 MBps read/write performance for both ext3 and NTFS
5) At least 4 drives - ewokNETGEAR Expert
I'll forward this to our build engineer and see what he can do. I was able to verify that copying a file with an ACL to an NTFS formatted drive produced an "Operation not supported" error. - mjw1Aspirant
Much appreciated. Did you perform the test on a Sparc device or an x86 device? Also, what version of ntfs-3g and what version of Linux were you running?
Also if you are able to determine what version of "fuse" we are using that could also be very helpful:
http://sourceforge.net/projects/fuse/files/fuse-2.X/
Thanks - ewokNETGEAR ExpertIt was on an NV+ using the latest in-house firmware.
- mjw1Aspirant
ewok wrote: I'll forward this to our build engineer and see what he can do.
Hi Ewok - Since about a week has passed I just wanted to check whether you ever heard back from your build engineer?
In the meantime another Readynas developer kindly built the package containing the bugfix for me ntfs-3g_2010.10.2AR2-1readynas-1_sparc.deb. I have been testing with this version and it solves the issue. With this fix it seems possible to retain ownership, permissions and ACLs (just like is possible with an EXT3 drive). This means that there are no more errors when running either cp -p or rsync -aAv.
By the end of this I realized that the existing Readynas Perl scripts (e.g. /frontview/bin/backup) would never work correctly with NTFS since they always use the -p option for cp and the -A option for rsync, both of which are invalid options for a filesystem that (prior to this fix) would not even allow chmod/chown. Probably the only reason that we didn't see these errors before was that the mount option "silent" was acting to suppress the errors. Interestingly the /frontview/bin/backup does contain a "FAT32 compatibility mode" that switches off the ownership/permissions/acl options for rsync but it looks like no such support was ever implemented for NTFS backups.
The only remaining questions/issues now are:
1. Where is the file on the Readynas that defines the mount options for ntfs-3g (I can't find it and it's not in /etc/fstab)?
2. We need to add the usermapping mount option (see NTFS-3G manual) and point it to a file somewhere on the main ext3 filesystem containing
At present I have manually created the UserMapping file on my NTFS drive inside a ".NTFS-3G" directory (which ntfs-3g checks for when it mounts the device). This works but you would probably be better off using the usermapping option for your official Netgear solution so that users can simply plug in any NTFS drive, and ownership, permissions and ACLs will work out-of-the-box.
3. When can this fix be rolled out to the rest of the Readynas community?
Thanks,
Mark - ahpsi1TutorWow, I am thoroughly impressed with how well you have documented and ultimately solved your problem with assistance from Netgear and other helpful developers.
mjw wrote: ewok wrote: I'll forward this to our build engineer and see what he can do.
No ETA as of yet. - ewokNETGEAR ExpertSo I tested the build of ntfs-3g and got the invalid argument error with cp like you mentioned in the other thread. rsync doesn't seem to error out though. cp-based backups will still fail.
- mjw1Aspirant
ewok wrote: So I tested the build of ntfs-3g and got the invalid argument error with cp like you mentioned in the other thread. rsync doesn't seem to error out though. cp-based backups will still fail.
Both cp and rsync worked in my tests so there must be some difference in our respective setups. It is possible to get the "invalid argument" error if you miss out step 5 in the instructions a couple of posts back. The error occurs when you execute a command that attempts to copy ACLs but you have not provided NTFS-3G with an ACL mapping file. I've also seen the same error when using any version of NTFS-3G except the absolute latest (ntfs-3g_2010.10.2AR2-1readynas-1_sparc.deb). Any earlier version still contains the bug. My suggestions would be to install this actual version rather than the one built by your build engineer at least initially so that we are certain to be running the same code.
You can also easily check the version as follows (but this doesn't immediately tell you if the Posix ACL compilation option was used):
# ntfs-3g --version
ntfs-3g 2010.10.2AR.1 integrated FUSE 28
Did you create your "UserMapping" file within the ".NTFS-3G" subdirectory and include the correct string? If not, then please try again after doing that.
Also, are you certain that the driver was compiled with the option to enable ACLs ("--enable-posix-acls" )? You can check if UserMapping has been specified and Posix ACL support is compiled in by mounting in "debug" mode using a mount command such as:
ntfs-3g -o debug,user_xattr,rw,sync,noatime,allow_other /dev/sda1 /USB/USB_HDD_1 2> /tmp/ntfs-3g.err
The driver will output something similar to the following into /tmp/ntfs-3g.err:
utime_omit_ok: 0
Version 2010.10.2AR.1 integrated FUSE 28
Mounted /dev/sda1 (Read-Write, label "OneTouch4", NTFS 3.1)
Cmdline options: debug,acl,user_xattr,rw,sync,noatime,allow_other,blksize=4096
Mount options: acl,rw,sync,allow_other,allow_other,nonempty,noatime,fsname=/dev/
sda1,blkdev,blksize=4096
User mapping built, Posix ACLs in use, configuration type 7
unique: 1, opcode: INIT (26), nodeid: 0, insize: 56
INIT: 7.8
If everything is working as expected you should see a line that says User mapping built, Posix ACLs in use, configuration type 7
Mark
