fneurieser
Aug 10, 2014Aspirant
[SOLVED] RN102 - Problems?! #23673790
Hello,
I'm not sure how to go on. I've a RN102 with 2 3TB WD RED disks (WD30EFRX) inside.
Yesterday I tried to setup for the first time but I got an IP different from my home network. So I changed ip on the NAS according to my network.
After that the NAS was unreachable. Therefore I decided to make a factory reset and now I can't find my NAS anymore.
2 Questions:
a) How long does it approximately take to make a factory reset with the above inventory using brand new disks?
b) is there a possibility to do a boot using usb-drive with firmware installed on?
Hope somone could answer my questions
2 Questions:
- mdgm-ntgrNETGEAR Employee Retireda) It shouldn't take long to do a factory reset. Just minutes.
b) That is a last resort. It is safer where possible to let us remote in and have a look.
Could you:
1. Open a support case (go to support.netgear.com and choose the email link on the contact us page)
2. Acknowledge your acceptance of our remote access policy: http://kb.netgear.com/app/answers/detail/a_id/20932/~/netgear-remote-access-policy
3. Place your NAS in tech support mode (http://kb.netgear.com/app/answers/detail/a_id/22892/~/how-do-i-access-the-boot-menu-on-my-readynas-102-or-312%3F)
4. Put the 5-digit ID found in the info (far right) column in RAIDar in the support case
5. Let me know the case number.
I think i know what the issue is and if it is what I suspect it is it should be a quick fix. - fneurieserAspirantHello again,
sorry for the delay but I had to leave for a few hours. The case number is 23673790 but I can't find the 5-digit ID.
The NAS is now in tech support mode.
Regards
Franz-Georg - StephenBGuru - Experienced User
Are you saying it isn't showing up in RAIDar?fneurieser wrote: ...but I can't find the 5-digit ID...
Or that you don't know how to install/use RAIDar? - fneurieserAspirantYes it doesn't show up in RAIDar!
- mdgm-ntgrNETGEAR Employee RetiredIs your NAS unit connected to your router?
- fneurieserAspirantyes
- mdgm-ntgrNETGEAR Employee RetiredMaybe you have a bad disk then.
- fneurieserAspirantboth disks a brand new, why did it work yesterday?
mdgm wrote: Maybe you have a bad disk then.
and what did you mean when saying
I think i know what the issue is and if it is what I suspect it is it should be a quick fix. - mdgm-ntgrNETGEAR Employee RetiredWell I think I may have guessed wrong.
Can you boot into tech support mode if you remove the disks?
