cobels
Mar 20, 2012Aspirant
Spotweb and Readynas
Does somebody know how to install spotweb on a readynas ?" If yes perhaps they could leave a small how to here, so that others can benefit from there experience. Thx in advance, regards.
InTheShires
Mar 22, 2012Tutor
The test file looks ok. (See screenshot) I've not progressed it any further than that, as I'm not sure it's of any use to me, and I'm short of time to dig deeper at the moment. Will try again at the weekend if time permits.
It was pretty straightforward to get that far though. You'll need to create your own "spotweb" (no quotes) database for it, (I use PHPMyAdmin) and you will have to grant permissions on the Spotweb directory (I temporarily put the dir' in Webroot to test) and restart Apache. I think that was about all I did.
Installation is covered here mostly. https://github.com/spotweb/spotweb
