cobels
Mar 20, 2012Aspirant
Spotweb and Readynas
Does somebody know how to install spotweb on a readynas ?" If yes perhaps they could leave a small how to here, so that others can benefit from there experience. Thx in advance, regards.
sign2apple
Dec 29, 2012Aspirant
Yeah having the same problem now after playing around with frontview which caused a apache restart.
I did solved this by making some changes in httpd.conf, but I removed this later, because I thought it was not necessary and that is why I didn't put it in the tutorial.
I lost the changes I made to httpd.conf, but I have a temporay workaround.
Rename .htaccess to something else:
This is not a really a good solution because we are missng some functionality now (https://github.com/spotweb/spotweb/wiki/Spotweb-als-Newznab-Provider)
but it works for now.
I will search for a better solution later and rewrite the tutorial.
cd /frontview/ui/resource/html/spotweb
mv .htaccess htaccess.bak
