cobels
Mar 20, 2012Aspirant
Spotweb and Readynas
Does somebody know how to install spotweb on a readynas ?"
If yes perhaps they could leave a small how to here, so that others can benefit from there experience.
Thx in advance, regards.
- dj_beirutAspirantI am having an issue with this when trying to connect with couchpotato and sickbeard
thing is they can't communicate.
i followed this tutorial:
https://github.com/spotweb/spotweb/wiki/Spotweb-als-Newznab-Provider
but i can't make it work with ReadyNAS since i can't figure out how to enable mod_rewrite and AllowOverride wich i think is the issue here.
when i try to test manually using:
http://server/spotweb/api?t=c
i get this error:
Not Found
The requested URL /c/www/spotweb/index.php was not found on this server.
can you please help?? - sign2appleAspirantTry adding those lines to httpd.conf add the end of the <Location /www> block and restart apache.
RewriteEngine on
RewriteCond %{REQUEST_URI} !api/
RewriteRule api/?$ spotweb/index.php?page=newznabapi [QSA,L]
Haven't fully tested couchpotato/newznab functionality yet, so the tutorial may need some modifications. - dj_beirutAspirantThanks...
Now i can actually see XML when i open: http://server/spotweb/api?t=c
but still can't make it work with couchpotato or SickBeard - sign2appleAspirantShould work with CP.
Works for me though.
Can you find something in CP's log?
Take a look at the requests CP makes to spotweb?
Do you see anny errors? - supahflyAspirantI am already having trouble with the install.php script, it says :
Database support NOT OK
MySQL (PDO) NOT OK
PostgreSQL (PDO) NOT OK
FreeType Support
Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 33
NOT OK
GIF Read Support
Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 34
NOT OK
GIF Create Support
Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 35
NOT OK
JPEG Support
Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 36
NOT OK
PNG Support
Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 37
NOT OK
I have Mysql up and running though ... anyone please help?
I also installed php from the link in the tutorial, so I have no clue what is the issue - supahflyAspirantAnyone? I'm really starting to hate my readynas as it is crappy to install somethin on it ...
