cobels's avatar
cobels
Spotweb and Readynas
Does somebody know how to install spotweb on a readynas ?"
If yes perhaps they could leave a small how to here, so that others can benefit from there experience.
Thx in advance, regards.
  • I am having an issue with this when trying to connect with couchpotato and sickbeard
    thing is they can't communicate.
    i followed this tutorial:
    https://github.com/spotweb/spotweb/wiki/Spotweb-als-Newznab-Provider
    but i can't make it work with ReadyNAS since i can't figure out how to enable mod_rewrite and AllowOverride wich i think is the issue here.
    when i try to test manually using:
    http://server/spotweb/api?t=c
    i get this error:
    Not Found
    The requested URL /c/www/spotweb/index.php was not found on this server.
    can you please help??
  • Try adding those lines to httpd.conf add the end of the <Location /www> block and restart apache.
      RewriteEngine on
    RewriteCond %{REQUEST_URI} !api/
    RewriteRule api/?$ spotweb/index.php?page=newznabapi [QSA,L]
    Haven't fully tested couchpotato/newznab functionality yet, so the tutorial may need some modifications.
  • Thanks...
    Now i can actually see XML when i open: http://server/spotweb/api?t=c
    but still can't make it work with couchpotato or SickBeard
  • Should work with CP.
    Works for me though.
    Can you find something in CP's log?
    Take a look at the requests CP makes to spotweb?
    Do you see anny errors?
  • I am already having trouble with the install.php script, it says :
    Database support NOT OK
    MySQL (PDO) NOT OK
    PostgreSQL (PDO) NOT OK
    FreeType Support
    Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 33
    NOT OK
    GIF Read Support
    Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 34
    NOT OK
    GIF Create Support
    Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 35
    NOT OK
    JPEG Support
    Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 36
    NOT OK
    PNG Support
    Notice: Undefined variable: gdInfo in /c/www/spotweb/templates/installer/step-001.inc.php on line 37
    NOT OK
    I have Mysql up and running though ... anyone please help?
    I also installed php from the link in the tutorial, so I have no clue what is the issue
  • Anyone? I'm really starting to hate my readynas as it is crappy to install somethin on it ...
ProSupport for Business
