STX1300MAN
Mar 16, 2011Star
Spurious UPS Alert?
My first post on the forum, though been a lurker for sometime :) I have installed a ReadyNAS Duo for a small office and also supplied an APC UPS BK350EI (a.k.a. CS-350) Everything is working f...
mdgm-ntgr
Mar 16, 2011NETGEAR Employee Retired
What version of RAIDiator?
What battery runtime is reported for the UPS under Status > Health in Frontview?
I think it is possible that the UPS battery needs replacing. You might want to hook the UPS up to a PC and run some diagnostics on the UPS using Powerchute.
Your UPS isn't on the HCL so I guess it's also possible that there's a compatibility issue.
