STX1300MAN
Mar 16, 2011Star
Spurious UPS Alert?
My first post on the forum, though been a lurker for sometime :) I have installed a ReadyNAS Duo for a small office and also supplied an APC UPS BK350EI (a.k.a. CS-350) Everything is working f...
STX1300MAN
Mar 17, 2011Star
What version of RAIDiator?
4.1.7
What battery runtime is reported for the UPS under Status > Health in Frontview?
100% 75 Minutes BUT Status shows as "Out of Spec"
I think it is possible that the UPS battery needs replacing. You might want to hook the UPS up to a PC and run some diagnostics on the UPS using Powerchute.
The UPS is only 2 weeks old so I'd hope the battery is OK, but you never know. I bought two of these UPS and the second was DOA.
Your UPS isn't on the HCL so I guess it's also possible that there's a compatibility issue.
No it's not, but the CS650 is (same family / carcase) and a few people have reported the model I am using as OK in the Community HCL.
Well, I shut everything down and restarted the UPS (which tests the battery) and no error reported.
Restarted the ReadyNAS Duo and the UPS Status is now OK.
Hopefully it was a communication glitch in the monitoring, but I'll keep an eye on it.
4.1.7
