netnewt
Sep 04, 2011Aspirant
Squeezecenter download for SPARC missing
Hi Netgear folks, The download links for the latest Squeezecenter add-on for the NV+ (SPARC version) all point to this link: http://www.readynas.com/?page_id=617 But it's not there? Even the ...
bethjim
Ok - if I get click on that link I get the following - (When you get to the "mysqueezebox.com/download" page click on the dropdown to get a menu of different versions. Pick the one for NV/Duo - that's what you want for your NV+.)
Download software:
Download the following files:
Squeezebox Server for ReadyNAS from: http://www.mysqueezebox.com/download
NOTE: There are two variants - the Pro/NX and the NV/NV+/Duo. Make sure to select the correct version for your ReadyNAS.
RAIDiator for ReadyNAS from: http://www.readynas.com/download. This is the firmware for the ReadyNAS.
CleanSqueezeCenter which resets all Squeezebox Server settings to default.
NOTE: There are two variants. Make sure to select the correct version for your ReadyNAS.
The Pro/NX version is here http://www.readynas.com/download/addons/x86/... and the NV/NV+/Duo version is here http://www.readynas.com/?page_id=617
After downloading, place all the files you downloaded in a folder on your desktop.
Launch RAIDar (Netgear software that discovers and connects to your ReadyNAS).
In RAIDar, click Setup.
Login to your ReadyNAS administration web page.
Update ReadyNAS firmware:
You will need to update your ReadyNAS’ firmware. To update your firmware, please do the following:
Go to System > Update > Local tab.
Click Browse and navigate to the folder wherein you previously stored the files you downloaded from Netgear.
Select RAIDiator and select ‘Upload and verify image’.
After the file uploads, click ‘Perform System Update’.
When the update completes, go to Shutdown > Shutdown and reboot your device > Apply.
After your ReadyNAS restarts, log back into the administration web page and proceed to the Run CleanSqueezeCenter step below.
Run CleanSqueezeCenter:
The CleanSqueezeCenter application returns all Squeezebox Server settings to their defaults.
In your ReadyNAS web administration page, go to System > Update > Local tab.
Select CleanSqueezeCenter and click ‘Upload and verify image’.
You will be prompted to restart your ReadyNAS.
Go to the Shutdown tab, select ‘Shutdown and reboot your device’ and click Apply.
After the ReadyNAS restarts, log back into the web administration page and go to the Remove and reinstall SqueezeCenter step below.
Remove and reinstall Squeezebox Server:
You will need to uninstall any previous version of Squeezebox Server on your ReadyNAS and install the new version you previously downloaded from the Logitech web site. To uninstall and reinstall, do the following:
On the ReadyNAS web administration page, go to Services > Streaming Services.
Check the checkbox next to SqueezeCenter, then click Remove.
Click Browse and navigate to the folder wherein you stored the files you previously downloaded from Logitech’s web site.
Select SqueezeCenter and click ‘Upload and verify image’.
After your ReadyNAS restarts, go to the Run CleanSqueezeCenter step below.
The CleanSqueezeCenter application returns all SqueezeCenter settings to their defaults.
After the ReadyNAS restarts, you should be able to access SqueezeCenter on your ReadyNAS.
That's about all I can do -
Jim
Download software:
Jim
