netnewt
Sep 04, 2011Aspirant
Squeezecenter download for SPARC missing
Hi Netgear folks, The download links for the latest Squeezecenter add-on for the NV+ (SPARC version) all point to this link: http://www.readynas.com/?page_id=617 But it's not there? Even the ...
jaime1
Sep 20, 2011Aspirant
I just went through this since It had been a long time since I updated this. First I had cleared the queezecenter once before. I had firmware 4.1.7. Today I updated to firmware 4.1.8. The update went fine, then I figured I update my squeeze center since it's a bit old. I just went a head and downloaded the nv file, went to the local tab and updated from there. I didn't even bother to uninstall the old one, I forgot. But it went fine. I didn't bother to run the cleaner either since I don't bother to make any other configurations. I did have to reboot after the update though. Now the server is scanning the library. It seems to take a bit longer than before though. I rescanned a few days ago with my old version and this new one is taking a bit longer, but it's the first time so we'll see. Well it finally finished but I still couldn't play anything from the screen. I just turned on the slimdevice and everything works again. Go figure.
