wagb4
Sep 11, 2014Aspirant
SSH Connect to NAS
Using a ReadyNAS model 102 with firmware version 6.1.8. I enabled SSH service but cannot mount a share using "sshfs". Has anyone been able to mount a share using SSH, and if so how do you do it? ...
mdgm-ntgr
Sep 11, 2014NETGEAR Employee Retired
SSH is enabled for the root user (has same password as the admin user). However if you use this you will likely run into permissions issues when trying to use the files via other protocols.
The setting under Support is for Remote access by support only.
