wagb4
Sep 11, 2014Aspirant
SSH Connect to NAS
Using a ReadyNAS model 102 with firmware version 6.1.8. I enabled SSH service but cannot mount a share using "sshfs". Has anyone been able to mount a share using SSH, and if so how do you do it? ...
wagb4
Thanks Guys.
What I want to do is mount a NAS Share on a LAN connected Linux computer so I can use a File & Directory sync application (such as DirSyncPro or FreeFileSync) to mirror some directories' contents to the NAS. Any suggestions are welcome. Both of those sync applications seem to want a remote device mounted using SSHFS and then use the local mount point as the destination of the sync operation.
