wagb4
Sep 11, 2014Aspirant
SSH Connect to NAS
Using a ReadyNAS model 102 with firmware version 6.1.8. I enabled SSH service but cannot mount a share using "sshfs". Has anyone been able to mount a share using SSH, and if so how do you do it? ...
xeltros
Sep 21, 2014Apprentice
you should be able to sync to an rsync server (the NAS has one in the settings on OS6) by using the user@IP:/folder pattern to connect in clear text. Of course if you want to user rsync over SSH this should be possible too, but I think you will have to enable the SSH server on the remote server.
Otherwise any mount should do fine and local rsync command will do the job afterwards.
