avicenne13
Feb 12, 2014Aspirant
SSH problem on Ultra 2
Hi Using the latest firmware on ReadyNAS Ultra 2. Enabled root SSH after OS reinstall. I get the following error: ssh [email protected] Connection closed by 192.168.1.88 Checked logs (boot...
avicenne13
Feb 16, 2014Aspirant
@mdgm thank you for your help offer, I've been away from the device for the last couple of days, will do if I go there.
But I discovered this:
Feb 16 17:48:58 vega sshd[6050]: error: @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Feb 16 17:48:58 vega sshd[6050]: error: @ WARNING: UNPROTECTED PRIVATE KEY FILE! @
Feb 16 17:48:58 vega sshd[6050]: error: Permissions 0670 for '/etc/ssh/ssh_host_rsa_key' are too open.
Feb 16 17:48:58 vega sshd[6050]: error: It is recommended that your private key files are NOT accessible by others.
Feb 16 17:48:58 vega sshd[6050]: error: This private key will be ignored.
Feb 16 17:48:58 vega sshd[6050]: error: bad permissions: ignore key: /etc/ssh/ssh_host_rsa_key
Feb 16 17:48:58 vega sshd[6050]: error: Could not load host key: /etc/ssh/ssh_host_rsa_key
Feb 16 17:48:58 vega sshd[6050]: error: Could not load host key: /etc/ssh/ssh_host_dsa_key
I think I know how it happened, I was trying to change the permissions of a file, but I most probably did it too generic. This was also the reason that I did a OS reinstall as well.
Any ideas on how to fix it?
