rolski
Oct 04, 2012Aspirant
ssh stopped working (connection abort) #19586817
I have perhaps a similar problem with my ReadyNas Ultra 4 plus. Since recent updates, root SSH access doesn't seem to work when using Putty. (referring to :- viewtopic.php?f=20&t=65601&hilit=ssh+sto...
rolski
A great help - very detailed & I was able to follow - but no joy....
I have exactly the result you list above : 22/tcp open ssh OpenSSH 4.3p2 Debian 9 (protocol 2.0) : but I still cannot get in with Putty.
Is there any reason that I can get in to my NV+ with Putty & not my Ultra4plus ?
And during updates / reboots, Putty either times-out or the "software" error message appears.
Is there any other way to get in other than Putty perhaps ? Or any settings on Putty that can be changed to help ?
Thanks !
Thanks !
