ILoveYou
Sep 08, 2023Aspirant
Startup issue and access lost (shares + frontview) on RNDU2000 OS6 (Ultra 2)
Hello, I use a readynas Ultra2 RNDU2000 with OS 6.10.8 + 2 HDD 8To Raid 1. I have an issue for a few days. I can no longer access the NAS, neither via the shares (SMB) nor via Frontview. I noticed...
Sep 08, 2023Guru - Experienced User
You might want to try using RAIDar to check the status with the 8 TB disks installed:
ILoveYou wrote:
I've done some research on the community posts and suppose the system disk is full:
That is a possibility, though it is possible something else is going on.
Did you try booting up the system with just disk 2 installed (leaving slot 1 empty)?
ILoveYou wrote:
1- remove the disks, mount them on a linux distribution (I have Ubuntu USB version), clean the disk: The problem is that when I do this I can't mount the disks. I don't know enough about Linux. I tried with mdadm but it didn't work => Does anyone have a clear procedure for accessing at least the system partition?
Note you also need to install btrfs on Ubuntu.
Instructions for data volume access depend a bit on the expansion history - when you converted to OS-6, did you start with 2x8 TB, or something smaller?
Note the OS partition is a fixed size, so that wouldn't depend on the expansion history.
ILoveYou wrote:
2- SSH access via the tech support boot menu, clean directories using command lines: in theory this seems possible:
but once I've started up in tech support mode, I can't connect via SSH (connection refused) nor Telnet (incorrect login)
Tech support mode requires telnet, not ssh. The user name is root, the password is infr8ntdebug
You will need more info to troubleshoot (starting raid, etc) - you can post back once you've sorted out the access problem.
ILoveYou
(My reply is automatically deleted ; I have a copy/paste. I will try again tomorrow...)
