Hillward
May 17, 2017Follower
Static IP address for Nas
How do I fix the IP address of the NAS so it is static. Please help
Sandshark
May 18, 2017Sensei
An OS re-install will switch it back to DHCP. Be careful not to do a factory default by mistake. Re-install loses no data and resets minimal things (DHCP and admin password), but a default wipes everything. Alternately, connect a PC directly to it and manually assign it an address in the same subnet, then go in and change the NAS to DHCP. If you have ReadyNAS Remote enabled, I think you can also still go in through that and change it.
Spike12
May 19, 2017Aspirant
Many thanks, I have an old XP machine which should do it.
That reply was a great help. I will let you know how I get on.
